Rough Idle Any Tips? Read post
Old Feb 15, 2021 | 04:15 PM
Millionmann's Avatar
Default Rough Idle Any Tips? Read post
Currently have a 2008 Model F250 which is the 2008-2010 model with the 5.4L engine. The truck will fire up no problem and runs super good well driving but if I let it idle after roughly 2 minutes it’ll slowly putter the idle down then die unless I give it gas then it’ll go up to 2000 rpm for a few seconds then back down to normal idle then die after the 2 minutes again unless I repeat. Any ideas?
Old Feb 16, 2021 | 07:32 AM
You might consider connecting a fuel pressure gauge to watch what the fuel pressure is doing at the time it dies.
Old Feb 16, 2021 | 10:07 AM
raski's Avatar
I would check fuel trims with a scan tool. That will give you which direction to go troubleshooting.
randypape
Jun 24, 2012 10:28 PM
gba3009
Feb 6, 2009 01:52 PM
racinteach
Jul 4, 2007 01:41 PM
BOBBY
Dec 2, 2006 01:57 PM
Jtoomey153@msn.com
May 12, 2006 10:43 PM
