sucking sound fuel filter f250 6.0 2004
Old Jun 11, 2017 | 04:14 AM
  #21
bismic's Avatar
With the key on, the fuel pump will run. Nothing to keep it from overflowing except you turning the key off.
Post a pic of the tube you are talking about.
The balloon test is testing for the same thing as the bubble test.
Are you sure that the blue spring kit was installed correctly? As I mentioned before, this could be the culprit.
Old Jun 11, 2017 | 11:07 AM
  #22
kodiak_f250's Avatar
That was going to be my next check, just going one by one until I find something that might be it. What could I have done wrong with the blue spring upgrade ? I followed the upgrade video if I remember correctly :-)
Old Jun 11, 2017 | 03:06 PM
  #23
bismic's Avatar
Post #8 mentions an o-ring that needs to be installed. Sometimes it isn't.
https://www.ford-trucks.com/forums/1...-problems.html
There are several versions of the upgrade kit. Maybe you didn't get the correct one, only you can discern that.
http://www.powerstroke.org/forum/6-0...de-issues.html
Old Jun 13, 2017 | 09:56 PM
  #24
ok guys, today I had a little time after work and I did the bubble test and guess what, no bubbles!!! I was nervous because I saw many on youtube that had bubbles, so this isolates out the injectors, is that right ? I am thinking this is good news.
When I filled the cup with fuel, also I didn't see that many bubbles coming from the feed pipe, but it must be coming from there, is that what this points to ?
thanks!
Old Jun 13, 2017 | 10:38 PM
  #25
bismic's Avatar
Take a look at this video. He cranks longer than you did.
Old Jun 14, 2017 | 10:12 AM
  #26
ok, today after work, I will try again, much longer....
Old Jun 14, 2017 | 03:25 PM
  #27
bismic's Avatar
You can crank for 20-25 seconds. Just give it time to cool afterwards - say wait 5 minutes.
I am not insisting that that is your issue, just suggesting to give it a full test.
I lean more towards the regulator.
Old Jun 15, 2017 | 10:07 AM
  #28
where is the fuel regulator, is that where the blue spring is ?
Old Jun 15, 2017 | 12:17 PM
  #29
bismic's Avatar
yes .
Old Jun 18, 2017 | 04:48 PM
  #30
ok, I'v made a longer test today, 25 seconds and still no bubbles....
so I started to remove the air filter housing, and when I have more time to get that all opened up...
