Switched from Chevy to ford
Old Jun 20, 2018 | 10:17 AM
Krhauling's Avatar
Default Switched from Chevy to ford
Hello. I just bought my first ford. 2018 f350 king ranch dually. Have always had chevys but I was impressed with truck and got it. I would like to have bigger wheels instead of the factory 17s. What is the biggest rim and tire I can have without any mods, lifts? Also if I do a 2 inch level on front what would be the biggest rim and tire? Thanks
Old Jun 20, 2018 | 10:24 AM
Thumbs up
Welcome and congratulations on the new rig?
are you planning on towing/fifth wheel with your truck?
Old Jun 20, 2018 | 12:01 PM
Krhauling's Avatar
I do pull a t190 bobcat weighs about 10k with trailer. But not planning on using 5th wheel. I didn't know if I could get the king ranch 20s that come on the f250 models. 17s just look small .
Old Jun 20, 2018 | 11:10 PM
Use Common Sense's Avatar
They probably would. However, the 18" & 20" are for SRW units and the 17" are for DRW units. I'm assuming that the 18" & 20" are not offered in the DRW units from the factory due to rubbing on the rear tires if there is any clearance at all between the rear duals.
Old Jun 21, 2018 | 12:32 AM
Krhauling's Avatar
That's what I was worried about also. Did not know about rear side by side clearance issues. On side note, the truck is amazing . Pulls better than my 2015 duramax did. The inside is so much nicer. Headlights are awesome .
Old Jun 21, 2018 | 03:42 AM
Glad you like it. I love my 2015 F-150 Lariat (ordered mine the way I wanted it...)
You might be able to get narrower tires than the standard 20" size that would allow you to run 20's on your buggy. That way, when you're loaded the side walls won't rub. Run a load range "E" and pump em' up... Might have to run it by a good tire shop on their thoughts.
Old Jun 21, 2018 | 11:08 AM
The other concern if at some point you tow in 5th/gooseneck is the bedrail height. Much taller than their earlier counterparts...
newguy18
Dec 29, 2007 10:25 PM
RS
Dec 17, 2007 06:09 AM
