Towing question
Old Mar 15, 2025 | 04:19 PM
Kodak's Avatar
Default Towing question
I have a 2018 f350 6.7l dually
OEM puck system for fifth wheel hitch.
The two front tires are constantly wearing on the outside of the tire after about 22,000 that isn't all tow miles. this is the second set of Michelins. The front end is lined up everything is in the green.
The total hitch weight in the bed of the truck is roughly 3,300lbs. The truck squats about 2, 2-1/2" . I am thinking on adding a leaf spring to reduce the squat. but I don't know if that's the problem. Anyone ??
Thanks
Mark
Old Mar 15, 2025 | 06:43 PM
Two things I would suggest,
First get rid of those Michelins,they were once a very good tire, but something went wrong on the way and they are not what they used to be..
Second, if the front tires have feather edges on the tread area, the vehicle might have excessive toe in.
If an auto shop did the alignment, better to have Ford do it.
Old Mar 15, 2025 | 11:37 PM
Did the shop provide you with 'initial and final' alignment report?l
Old Mar 16, 2025 | 03:05 AM
Kodak's Avatar
They did showed everything in the green. The alignment was preformpreformed by a Ford dealer.
Old Mar 16, 2025 | 03:09 AM
Kodak's Avatar
Any suggestions on a tire ?
I was thinking about adding a leaf spring, but I don't know if that's the problem.
rafanbill
Aug 19, 2023 04:27 PM
Charis047
Jul 14, 2020 09:57 PM
Bdmgolfer
May 19, 2020 04:09 PM
lyleb
Nov 23, 2009 04:23 PM
rollingstone
Oct 17, 2007 10:29 PM
