water in fuel?
Old Mar 16, 2006 | 03:18 AM
deluna's Avatar
Default water in fuel?
Can somebody please tell me how to drain the water in the fuel please. i have a 04 F-350 and the light has been on for about 2 weeks already. i looked in the manuel and cannot find where it is.
Old Mar 16, 2006 | 06:19 PM
Lone Ranger's Avatar
Default RE: water in fuel?
Mine is an 03 Powerstroke 7.3 Diesel.. When asking a question like that, you need to tell what engine... Water in fuel? Good Lord! Deluna, I would not let that go for two hours let alone two weeks if it was a psd engine like mine... On top of the engine, behind the filter is a lever. By moving the lever it drains the water seperator in the fuel filter... It will run out on the ground. If you were to put an extended hose on it, you could drain it to a clear bottle and see when the water was out and clean fuel running.. Probably less than a cup to drain at most...
Regards from the Lone Ranger in Australia...
Old Mar 22, 2006 | 09:39 PM
RNGMSTR's Avatar
if you have the 7.3, the lever is yellow and it right behing the fuel bowl on the left side(from the front of the truck) If you have the 6.0 you have to use an allen wrench to remove the drain plug on the driversside frame rail right by one of your two fuel filters.
buster97
Jun 4, 2009 02:24 PM
JTGrant1
Mar 11, 2009 02:50 PM
jwmghf
Jun 8, 2006 01:06 AM
MR WHISKERS
Jul 4, 2005 12:11 AM
sandman
May 13, 2005 01:00 AM
