Water in my back panel
Old Feb 15, 2024 | 05:40 PM
Spellmanck's Avatar
Default Water in my back panel
Any advice would be greatly appreciated!!
I left my slider window in the back of my truck behind the back seats slighly open during several days of rain (I was away)
now I have water sloshing around in that back panel. I cannot for the life of me find where to drain it from. I've exhausted youtube and I was under there....cannot find the plug to drain it
Any ideas? thank you in advance for any advice
Old Feb 15, 2024 | 08:25 PM
You may need to remove the seats to gain access to the bottom of the area, but you might be able to drill a small hole near that bottom and allow the water to drain out.
A 1/8 size drill carefully used would be all you need, just don't go deep because you could drill through the ares to the outside then it might drain out there , but now you created a place for rust to begin. That metal is not that thick so if you are successful just put a small short sheet metal screw with some sealer in the hole when done
Old Feb 15, 2024 | 09:02 PM
Spellmanck's Avatar
Default Thank you
I never thought to go at it from inside so that's a good thought.
And I did see an area where I thought there should be a plug so I will try that...GREAT idea about putting the screw in the hole
Thanks!!
Homebrewdr
Dec 4, 2025 11:20 PM
Joe Reeves
Dec 13, 2013 11:43 AM
BlackSton3
Sep 7, 2011 07:57 PM
sumnerdave
May 11, 2007 01:36 PM
dee004
Apr 21, 2007 05:23 PM
