Wheel locks and no "key"
Old Feb 10, 2008 | 12:33 PM
fmclandry's Avatar
Default Wheel locks and no "key"
I bought my truck second hand and the wheels have wheel locks. Help...help...help. I heard a rumor that a tire store might have master keys that will get them off? I heard a rumor that they can be drilled/sawed/cut off at a tire store? Since the truck is second hand I have no idea what company the wheel locks came from. Can I get them off somehow or just quickly sell the truck before I have a tire or front end alignment problem.?
Old Feb 11, 2008 | 02:40 PM
Level2's Avatar
Default RE: Wheel locks and no "key"
The cheapest and easiest way I know of to get them off is to take an old socket and weld it to the wheel lock, then instert the ratchet or breaker bar and take them off. At the worst, you sacrifice 4 sockets but you have the stupid locks off.
Old Feb 13, 2008 | 06:26 PM
fmclandry's Avatar
Thanks for the input. I talked to a tire store and it will cost between $5-$25 per wheel lock to force them off. Plus the previous owner must have really loved these tires because each wheel has TWO LOCKS! The mechanic that was passing through the showroom to get a cup of coffee almost died laughing when he heard that.
Old Feb 13, 2008 | 06:46 PM
Level2's Avatar
I could still get them off cheaper with 8 sockets and a welder. If its just $5 a piece I would let them do it but not at $25 a wheel.
Old Feb 14, 2008 | 02:02 AM
6Leaker's Avatar
Phone McGard, they sell replacement keys. I don't have the number off hand, as I'm not at work.
Old Feb 16, 2008 | 04:08 PM
meojeo's Avatar
Talked to a kid worked at a tire shop said they took a socket just undersize hammered it on. Stated they had one auto dealer who bought auction autos out of CA. and had a good stream of customers with this problem.
Old Feb 19, 2008 | 05:54 PM
BRETM's Avatar
MCGARD PHONE NUMBER IS 1800-444-5847.FIRST PROBLEM IS IT EVEN A MCGARD LOCK.SECOND YOU WILL NEED TO KNOW WHAT KEY NUMBER YOU NEED TO ORDER IT
Old Feb 23, 2008 | 08:31 PM
hobbywelder's Avatar
the welding will work and5 to 25 times 8no matter how i look at it the best way if you dont mind to buy new tools is go to sears or your local parts (chain) store and get some of those bad stud and rounded bolt socets i got some for the sam reson and they work great at $25 and used them for other thing sense thennow intuction say to use whench but i used 1/2 impact and socket just be carefull not to pull the trigger wide open but works wonders
Old Mar 14, 2008 | 04:10 PM
50stangMang's Avatar
Default AT MY SHOP
yeah we just break them right off the stud if the stud breaks in the process then we install a new one/.
Hambrock10
Jul 10, 2013 05:11 PM
NathanHale
Mar 30, 2009 06:18 PM
Pastor Wells
Jul 11, 2007 08:46 AM
Pastor Wells
Jun 30, 2007 08:21 PM
