06 Ford 500 Charging issues.
Old Feb 24, 2024 | 11:48 AM
Jay-B's Avatar
Default 06 Ford 500 Charging issues.
Hello. After reading and reading I've decided to ask. The car sat for almost a year. Originally I just thought it was the Alt. It would measure at the battery up to 12.5 to 12.8 and drop down to 3.8 or more (erratic) and light would come on dash. Higher rpms it would go out. Bat was old. Put a new one in. Now I'm getting nothing. No light and system check of car says charging system good. But batt drains in about 20 miles. I've read somewhere that could be chaffing of wires somewhere along the ac line, can't find, with possible other issues. I'm not a big fan of reman alts and funds are a little tight. Any ideas? Thanks in advance
Old Feb 27, 2024 | 08:40 AM
DIY Fan's Avatar
You can get a fully new alternator from Rockauto for around $140. Getting the new alternator in is a bit of a tetris puzzle since there is not much room back there. Before buying any parts I suggest eyeballing the wires to make sure there is nothing obviously loose that is causing the issue. Some of the mounting bolts have to be done by feel since its not possible to see them. Good luck!
Old Feb 28, 2024 | 06:20 PM
Jay-B's Avatar
​​​​​​Thanks. Yeah I if price some alternators I'm going to get one. I had just read that something about the computers and some remanufactured alternators don't communicate properly. If you know what I mean. I've just done a lot of reading about charging issues with these. Hopefully I'll grab an alternator soon and let you know. Thanks again!!
Old Feb 28, 2024 | 10:40 PM
DIY Fan's Avatar
Its also possible that mice have chewed some alternator cables since the car was sitting for so long. A visual inspection would confirm or deny that.
Old Feb 29, 2024 | 06:50 AM
jessec's Avatar
Is a new alternator from Napa anew good on ford 500
Old Feb 29, 2024 | 08:19 AM
When you purchase an alt from NAPA, make sure to ask if you have a choice of a cheap one or good one. You get what you pay for.
SpicyFly
Apr 16, 2022 12:26 PM
SpicyFly
Apr 15, 2022 10:35 PM
Shawn68
Jan 27, 2019 06:21 AM
browland
Jun 13, 2011 05:06 PM
Bonnieangel73
Jun 6, 2011 09:04 AM
