Heat stops working unless on max after running for a while
Old 10-16-2017, 03:34 AM
cleocutie's Avatar
Default Heat stops working unless on max after running for a while
I have a 2007 Ford Five Hundred and it has a very odd heat problem. When I first start it it has heat, no matter what temperature I have it set on. But after driving it a while the only way I can get it to give me heat is if I set the temperature control as high as it will go. What would cause it to have heat at first, then stop and possibly even odder- not have any heat unless the temperature control is on the hottest setting.
davetully
02-24-2013 05:51 AM
Blackstingray
01-08-2013 07:15 PM
yayeer
06-12-2012 11:44 AM
helpmyford
04-07-2010 01:03 PM
96F350Panel
11-27-2007 02:59 PM
Quick Reply: Heat stops working unless on max after running for a while
