2002 Explorer won't start unless switching from Park to Neutral and back
Old Feb 23, 2013 | 10:51 AM
davetully's Avatar
Default 2002 Explorer won't start unless switching from Park to Neutral and back
Hope somebody can help. I have a 2002 Ford Explorer.
It randomly will not start until we shift from Park to Neutral and back sometimes up to 3 times. It appears to be occurring more frequently.
Ideas?
Old Feb 23, 2013 | 12:36 PM
Part of the starter activating circuit was controlled by what was formally known as the neutral safety switch and now is known by the term trans range switch (same part). I would suspect either the switch is faulty or the linkage at the switch on the side of the transmission may be slightly out of adjustment. Some vehicles have a nylon piece that has a serrated surface and involves releasing the nylon retainer and repositioning the cable from the shift lever and the range switch so as to make good contact in the park or neutral position. Not a difficult thing to check and correct if necessary.
Old Feb 24, 2013 | 05:51 AM
davetully's Avatar
Thanks for the info!
maxpower
Jun 24, 2013 08:58 PM
Sam Graham
Dec 6, 2012 08:05 PM
TIMF150
Aug 31, 2012 11:51 AM
yayeer
Jun 12, 2012 11:44 AM
helpmyford
Apr 7, 2010 01:03 PM
