2005 freestar coilpack, wires, and plugs cost
Old May 15, 2016 | 08:41 PM
taurustimmy's Avatar
Default 2005 freestar coilpack, wires, and plugs cost
2002 Windstar had the same codes, "Misfire 3 and 4." and it turned out to be a bad coil pack. Now 2005 Freestar throwing same codes. How much to have a ford dealer do the coil pack, all wires and plugs all at the same time?
Old May 17, 2016 | 02:43 PM
Alanah_Rae's Avatar
welcome mate !!
Old May 17, 2016 | 11:25 PM
Use Common Sense's Avatar
Depends on what they charge per hour and what they charge for parts. You should be able to get a quote from them. Should only be about 2-2.5 hours worth of work as the upper and lower cowl needs to be removed to gain access to the rear plugs, wires and coil.
Old May 18, 2016 | 03:53 PM
LakelandFordParts's Avatar
Former Sponsor
The Ford part number for your coil pack is 5F2Z-12029-AD (#5F2Z12029AD: Coil. Ignition coil.)... I am not quite sure what the service charge would be but I would assume it would be a few shop hours running around $115/hr.
Old May 19, 2016 | 01:04 PM
Alanah_Rae's Avatar
Thanks for the informations sharing lake !!
NYRPM
Mar 5, 2018 12:33 AM
jcasaccio
Nov 2, 2009 06:24 AM
haledonoem412
Dec 21, 2006 12:33 AM
jeninejessica
Jun 22, 2006 11:10 PM
