Alignment
Old Jul 27, 2015 | 07:04 PM
saemetric's Avatar
Default Alignment
Anyone know the front alignment specs for my 2005 Ford 500.
Old Jul 27, 2015 | 09:28 PM
primem's Avatar
sorry...gotta ask. seems like a strange request...are you trying the dreaded driveway alignment?
Old Jul 27, 2015 | 10:09 PM
saemetric's Avatar
No just would like to know, especially the camber . Looking at car, it looks like car has too much neg. camber in front.
Old Jul 28, 2015 | 07:11 AM
primem's Avatar
front camber specs
fwd -0.60* +/- 0.75*
awd -0.40* +/- 0.75*
look at the tire wear pattern. irregular tire wear patterns will tell you more than what you can determine visually looking at a suspension part.
when springs sag, camber goes negative and toe goes positive. toe is the biggest tire wear angle. You would see toe wear long before camber wear.
perform a front suspension check to ensure the tie rod ends, ball joints and controls arms are not ready to fall out.
Old Jul 28, 2015 | 11:48 AM
saemetric's Avatar
Inside edge on both front tires are worn like this
Old Jul 28, 2015 | 11:52 AM
saemetric's Avatar
Everything on front suspension seems ok..Can't find and worn or loose parts
Old Jul 28, 2015 | 11:54 AM
saemetric's Avatar
front camber specs
I assume toe out or too much neg. camber could cause this?
Old Jul 28, 2015 | 06:16 PM
primem's Avatar
can't tell from the pictures.
run your hand along the worn area of the tire. Is the wear pattern smooth or featheredged saw toothed? if its saw toothed the issue is incorrect toe setting. the tire is scrubbing off and it rolls down the road.
when the wear pattern gets bad enough, the tires will create a lot of road noise...growl sound similar to a bad wheel bearing.
if you get an alignment, make sure its a 4 wheel alignment. tell them to provide you with a printout of the initial and final alignment readings.
Old Jul 28, 2015 | 09:03 PM
saemetric's Avatar
Yes it is feathered saw toothed . Quess that points to incorrect toe setting.
2verb
Jan 7, 2014 11:32 PM
MHartley
May 6, 2013 11:25 AM
tharp_michelle
Dec 29, 2006 10:46 PM
schwefls
Dec 17, 2006 07:43 AM
flyford
Mar 15, 2005 05:02 PM
