Car won’t start making clocking sound.
Old Oct 1, 2022 | 06:37 AM
Shuntsman23's Avatar
Default Car won’t start making clocking sound.
My mom has a 2005 Ford Five Hundred 40k miles And the back up lights were on when in park or driving. And the dash lights did not come on. They replaced the battery and alternator. And a week later the car won’t start now. It makes clicking sounds when you turn the key. It has been connected to the computer 3 times and shows no codes.
Old Oct 1, 2022 | 07:11 AM
Sounds like someone is playing a guessing game with your mom's car.
They replaced the battery and alternator and probably never checked the battery cables and connections that connect to the vehicle..
Usually a clicking sound when attempting to start a vehicle is caused by insufficient power to get the starter to engage fully and crank over the engine so it can start running.
You didn't state the mileage, or if there were any other problems..
It could be a questionable starter, corroded cable connections or corroded cables.
There could also be a power drain that is pulling down a new battery.. All these things need to be checked .
Old Oct 1, 2022 | 12:27 PM
She took it to two different Ford dealerships.
Old Oct 1, 2022 | 02:00 PM
Exactly what does the bill say they did ?
Will it start with a jump start?
If you turn the headlights on and attempt to start the engine, what do the headlights do?
Nothing, ,,go dim,,go out completely ?
If you want to help yourself, maybe we can offer some troubleshooting tips. Do you have any hand tools to use?
Old Oct 4, 2022 | 12:28 AM
Yes it starts with jump start drives fine but something is making the battery drain really fast.
Old Oct 4, 2022 | 08:39 AM
Not all problems will throw a code.
Something is staying on when it should be off.
One way you can find the "Problem area" is to monitor the drain and remove fuses one at a time until the drain stops.
The preferred method is to measure the voltage drop across each fuse with engine off. One will have a much higher reading than the rest and that is the circuit you need to check further . This is what the dealership should have done.
Mrhearne
Jan 6, 2023 09:49 AM
Shuntsman23
Oct 1, 2022 05:52 AM
MrsDeago
Jan 25, 2019 03:42 AM
nbarr7655
Dec 13, 2012 05:02 AM
lharmon
May 28, 2011 12:55 PM
