Clunck in front when when turning???
Hello all,
Im a new guy looking for insight. I have a '06 500 CVT, AWD limited with 90000 miles, , i noticed yesterday evening when backing and turning the wheel i heard this clunk. It was when i had steering wheel turned all the way( backing out of my fathers drive way). When i pulled in to my drive way i tried to reproduce the noise and got a little clunk, ( had wheel turned all the way again). I checked my PSF it was at the min line, I filled it up. turned the wheel back and worth when in park and no noise! but when i started to back up BOOM there it was again. I only hear it when the wheel it turned all the way, other time. Im just lost. So my fellow 500 Drivers, can you shed a little insight on to my situation
Best guess. Aside from a fluid leak and air in the line.
CV, constant Velocity joint needs to be serviced or replaced. Any torn boots?
Or your slamming by turning too hard, the moving part into the block that is welded in place to stop you from turning too far and wrecking a CV joint.
Again best guess.Throw a couple of jack stands under the front end of her and have somebody turn lock to lock with engine running and listen for the clunk. Keep it in park so you don't drive off the jack stands. If there is no noise then it may be the CV joints when they are driving the wheels and that probably means something in the CV joint is coming apart.
skip.
skip.
I'm not the best at describing a noise, but when I back up in my driveway, and turn the wheel all the way, I'm hearing a " creeching" type noise. I had a mechanic look at it, they could hear the noise but could not duplicate it when it was up on their in rack. They said all the front end looked good. So no work performed, but my 06 Ford 500 still does this when backing up and turning the wheel to the end. Thanks
Daughter-in-law's Honda makes such a sound when turning if fluid is low.
