latest/last software versions
Old Jun 15, 2020 | 10:31 AM
xusarmy's Avatar
Default latest/last software versions
I have a 2005 Ford Fivehundred SE. Im recently running into an issue that related to the following TSB:
Ford Five Hundred Headlight issue:
TSB
05551 INTERMITTENT HEADLAMP FLICKER WITH NO KEY IN THE IGNITION - VEHICLES BUILT BEFORE 2/21/2005
NHTSA ID #10014682
Publication Date: March 21, 2005
FORD: 2005 Five Hundred, Freestyle
MERCURY: 2005 Montego
ISSUE:
Some 2005 Freestyle, Five Hundred and Montego vehicles built before 2/21/2005 may exhibit the headlamps flickering intermittently, with no key in the ignition.
ACTION:
Reprogram the smart junction box (SJB) to the latest calibration using WDS B36.0 or higher. Calibration files may also be obtained at www.motorcraft.com. The procedure to reprogram the SJB is virtually the same as reprogramming a powertrain control module (PCM), except when selecting the module to be programmed, select the SJB (WDS may refer to it as the GEM).
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
OPERATION DESCRIPTION TIME
050501A 2005 Freestyle, Five Hundred, Montego: Check For Diagnostic Trouble Codes And Reprogram The Smart Junction Box (SJB) (Do Not Use With 12650D, 12650D84, 12651D, 12651D4) 0.4 Hr.
DEALER CODING
BASIC PART NO. CONDITION CODE
14C184 04
Here is a list of modules that I would like confirmation on what the latest or last software version is so I can understand if my Ford Dealership screwed me out of $129 for updating the GEM module, or if they even updated anything. Any assistance would be greatly appreciated. Here is the current GEM module:
GEM - Generic Electronic Module
Part number: 5F9T-14B476-AX
Strategy : 5G1T-14C184-AM
Software version: v14
Thank you,
Todd
Old Jun 16, 2020 | 11:12 AM
scott.butler4's Avatar
Vehicle is to old for the current software programming to be listed using the VIN on the ford site.
Pay should have been only 0.4 labor, based on you saying $129 I assume they charged a full hour instead.
Always sad to hear another dealer screwing a customer over, some of us are good.
If you go to another dealer who doesnt screw you over they can check if the SJB is already up to date on programming.
Old Jun 19, 2020 | 04:20 AM
raski's Avatar
That labor amount is what the dealer would get as a warranty claim from the manufacturer not what they would bill as an out of pocket expense to a customer .Service departments may have a one hour minimum for out of warranty work.
cngizbleevng
May 18, 2020 07:02 PM
cngizbleevng
May 18, 2020 01:37 PM
cmaidana
Jan 9, 2009 06:49 PM
chic
Mar 23, 2008 10:15 AM
hicracer
Feb 8, 2005 12:19 AM
