Quick question
Old May 2, 2022 | 08:31 AM
zombieoverlord's Avatar
Default Quick question
When I start my 2006 Five Hundred the rpms stay kind of high, about 1300rpms, and then slowly drop to normal idle, like 700/800 rpm. Other times the needle will jump to over 2000 rpms on starting and then drop to less then 1000rpms.
What's causing this spontaneous leap in rpms?
Thanks!
Old May 2, 2022 | 09:19 AM
A lot of engine RPM when cold or first started is determined by what the computer receives as present engine temp.
Higher RPM when cold speeds up warm-up.
Before replacing anything, best to verify engine coolant temp info with a scan tool
lpcraneman
Feb 14, 2011 03:16 PM
ddvargo
Sep 14, 2009 10:15 AM
asumom3
Jan 26, 2009 09:43 PM
haledonoem412
Aug 1, 2008 08:13 AM
haledonoem412
Apr 23, 2008 09:13 PM
