Replaced engine in 06 Ford five hundred
Old Jan 20, 2019 | 09:06 PM
Herb Hall's Avatar
Default Replaced engine in 06 Ford five hundred
We replaced the motor in our Ford five hundred everything is bolted up but when we hit the ignition all light come on but no starter engagement. Not even a click. Found a ground wire hooked up to the starter and swapped it with the white red wire. Still no starter engagement we tried to jump the starter and it started but would not turn off with the key. Hopefully someone can help us figure this out it is an 06 Ford five hundred limited all wheel drive with the 3.0 in it also the brake lights are staying on. U hook the brake light switch and they go off. Could this be part of my problem as well
Monarch36
Aug 19, 2009 05:36 AM
87ford150longbed
Feb 5, 2008 02:42 PM
sistreat
Mar 4, 2007 09:49 AM
dannyf150
Feb 25, 2007 03:10 AM
jr1017
Oct 11, 2006 02:18 PM
