Weird no start
Old Jul 22, 2022 | 09:41 AM
zombieoverlord's Avatar
Default Weird no start
2006 ford five hundred 3.0L 2wd. Replaced a brake caliper yesterday. Went to start the car and it wouldn't turn over. Had a very weak crank. Then the tachometer needle sporadically bounced up and down for a few seconds. It did that a couple times before it finally turned over.
What the hell was that?! I had a non start issue a few months ago that was solved by replacing the fuel rail pressure sensor i think it was? It was similar to that but without the needle jumping. No check engine light, no other problems other then a small exhaust leak that I need a gasket to fix.
Thanks in advance!
Old Jul 22, 2022 | 02:39 PM
raski's Avatar
.The crank sensor will not affect the cranking ability of the starter You said "engine wouldn't turn over and had a very weak crank".. I suggest you start by getting the battery tested and the battery connections cleaned up. If the engine is barely cranking, I wouldn't expect the tach to be displaying properly.
Get the engine's starting system working first and address any other issues thereafter.
Old Jul 22, 2022 | 04:34 PM
Default Re:
The battery is fairly new and the terminals are clean. Its happened that two times and never before that. Thos morning it started right up and it had a weak crank but turned right over at lunch.
CRiNT
Jan 31, 2022 06:51 PM
hfb1957
Jun 26, 2021 04:51 AM
nbarr7655
Dec 13, 2012 05:02 AM
adogsdomain
Nov 14, 2010 07:42 PM
jocasio
Dec 19, 2007 09:28 AM
