2006 Ranger hard to start
Old Apr 16, 2021 | 07:12 PM
hfb1957's Avatar
Default 2006 Ranger hard to start
2006 Ranger has to turn over for a long time before it will start. Once it starts it runs fine, but some times I think it will never start. I just replaced the idle air control valve. It is a 2.3 liter engine. Any ideas on where to start will be greatly appreciated.
Old Apr 18, 2021 | 07:30 AM
raski's Avatar
For a start, fuel pressure/flow should be checked. Try cycling the key several times before cranking to see if the engine starts any easier. How well has the vehicle been maintained? Old worn out ignition parts should be replaced.
Old Apr 18, 2021 | 07:06 PM
hfb1957's Avatar
Tried the key on and off a few times and that didn’t help. Sometimes it does fire right up and sometimes takes forever to start. Plugs are relatively new. It doesn’t have a check engine light on. Any help is appreciated.
Old Apr 19, 2021 | 07:37 AM
raski's Avatar
I would still check fuel pressure.
Old Jun 26, 2021 | 04:51 AM
Akbar Adeli's Avatar
Hi,
The most common causes that hinders normal starting operation of your Ranger are dead key fob battery, dead 12v battery, corrosion on battery terminals, bad alternator, clogged fuel filter, broken starter, blown fuse, empty gas tank, immobilizer error or any fault in the electrical system.
jerry101
Jul 7, 2013 09:35 AM
jerry101
Jul 7, 2013 09:33 AM
tazzy
Aug 29, 2010 09:08 PM
bneighbor_2005
Jan 21, 2009 04:41 PM
tjmo
Aug 30, 2007 02:30 PM
