2012 Focus SEL, revs high, throws multiple codes
My gfs car has done this twice now in the last two months, fixed both times by a battery disconnect:
The check engine light comes on, and the car revs way higher than normal when casually accelerating. Ran codes both times and it's the same, posted below, it's a lot. ECM, TCM, Coolant Temp, Transmission, feels like every code possible.
On mobile, trying to upload a video but can't tell if it's uploading. Touching the gas peddle to where it would normally go to 1.5-2k rpm, but the car goes to 3-4k rpm.
Anyone else experience this? Seems timing related but nearly everything related throws a code. Thanks.
============1==============
P0010
Raw code: 0010
ECU: Engine control unit
Status: Confirmed
OBDII: Camshaft position (CMP) actuator, intake/left/front, bank 1 - circuit malfunction
============2==============
P0010(00)
Raw code: 001000
Status: Test failed, Test failed (current drive cycle), Pending, Confirmed, Test failed since last DTC clear, Warning indicator requested
============3==============
P0702(00)
Raw code: 070200
ECU: Transmission control unit[Archive (inactive)]
Status: Test failed since last DTC clear
OBDII: Transmission control system - electrical
Ford: Transmission Control System Electrical
============4==============
P07A4(00)
Raw code: 07A400
OBDII: Transmission friction element B - performance or stuck off
============5==============
P0882(00)
Raw code: 088200
OBDII: Transmission control module (TCM) - power input signal low
============6==============
P2701(00)
Raw code: 270100
OBDII: Transmission friction element B, apply time - range/performance problem
============7==============
P0011(00)
Raw code: 001100
Status: Test not completed since last DTC clear, Test not completed during this operation cycle
OBDII: Camshaft position (CMP), intake/left/front, bank 1 - timing over-advanced/system performance
============8==============
P0012(00)
Raw code: 001200
OBDII: Camshaft position (CMP), intake/left/front, bank 1 - timing over-retarded
============9==============
P0014(00)
Raw code: 001400
OBDII: Camshaft position (CMP) actuator, exhaust/right/rear, bank 1 - timing over-advanced/system performance
============10==============
P0015(00)
Raw code: 001500
OBDII: Camshaft position (CMP) actuator, exhaust/right/rear, bank 1 - timing over-retarded
============11==============
P0016(00)
Raw code: 001600
OBDII: Crankshaft position/camshaft position, bank 1 sensor A - correlation
============12==============
P0017(00)
Raw code: 001700
OBDII: Crankshaft position/camshaft position, bank 1 sensor B - correlation
============13==============
P0087(00)
Raw code: 008700
Status: Test not completed during this operation cycle
OBDII: Fuel rail/system pressure too low
============14==============
P0088(00)
Raw code: 008800
OBDII: Fuel rail/system pressure too high
============15==============
P0111(00)
Raw code: 011100
OBDII: Intake air temperature (IAT) sensor - range/performance problem
Ford: IAT Circuit Range/Performance Problem
============16==============
P0116(00)
Raw code: 011600
OBDII: Engine coolant temperature (ECT) sensor - range/performance problem
Ford: ECT Circuit Range/Performance Problem
============17==============
P0128(00)
Raw code: 012800
OBDII: Coolant thermostat - coolant temperature below thermostat regulating temperature
Ford: Coolant Thermostat Malfunction
============18==============
P0133(00)
Raw code: 013300
OBDII: Heated oxygen sensor (HO2S) 1, bank 1 - slow response
Ford: Heated O2 Sensor Circuit Slow Response (Bank 1, Sensor 1)
============19==============
P013A(00)
Raw code: 013A00
OBDII: Heated oxygen sensor (HO2S) 2, bank 1 - slow response rich to lean
============20==============
P013E(00)
Raw code: 013E00
OBDII: Heated oxygen sensor (HO2S) 2, bank 1 - delayed response rich to lean
============21==============
P0217(00)
Raw code: 021700
OBDII: Engine over temperature condition
Ford: Engine Overtemp Condition
============22==============
P0218(00)
Raw code: 021800
OBDII: Transmission over temperature condition
Ford: Transmission Overtemp Condition
============23==============
P0219(00)
Raw code: 021900
OBDII: Engine over speed condition
Ford: Engine Overspeed Condition
============24==============
P0297(00)
Raw code: 029700
OBDII: Vehicle over-speed condition
============25==============
P0298(00)
Raw code: 029800
OBDII: Engine oil temperature too high
============26==============
P0420(00)
Raw code: 042000
OBDII: Catalytic converter system, bank 1 - efficiency below threshold
Ford: Catalyst System Efficiency Below Threshold (Bank 1)
============27==============
P0442(00)
Raw code: 044200
OBDII: Evaporative emission (EVAP) system - small leak detected
Ford: Evaporative Emission Control System Leak Detected
============28==============
P0455(00)
Raw code: 045500
OBDII: Evaporative emission (EVAP) system - large leak detected
Ford: Evap Emission Control System Leak Detected (Gross Leak/No Flow)
============29==============
P0460(00)
Raw code: 046000
OBDII: Fuel tank level sensor - circuit malfunction
Ford: Fuel Level Sensor Circuit Malfunction
============30==============
P0505(00)
Raw code: 050500
OBDII: Idle speed control (ISC) system - malfunction
Ford: Idle Air Control System Malfunction
============31==============
P050A(00)
Raw code: 050A00
OBDII: Idle air control (IAC) valve, cold start - performance problem
============32==============
P050B(00)
Raw code: 050B00
OBDII: Ignition timing, cold start - performance problem
============33==============
P050E(00)
Raw code: 050E00
OBDII: Exhaust temperature, cold start - out of range
============34==============
P052A(00)
Raw code: 052A00
OBDII: Camshaft timing - cold start, bank 1 - timing over-advanced
============35==============
P052B(00)
Raw code: 052B00
OBDII: Camshaft timing - cold start, bank 1 - timing over-retarded
============36==============
P053F(00)
Raw code: 053F00
OBDII: Cold start fuel pressure - performance problem
============37==============
P0572(00)
Raw code: 057200
OBDII: Cruise control/brake switch A - circuit low
Ford: Cruise Brake Switch Circuit Low
============38==============
P0573(00)
Raw code: 057300
OBDII: Cruise control/brake switch A - circuit high
Ford: Cruise Brake Switch Circuit High
============39==============
P1001(00)
Raw code: 100100
Ford: KOER Not Able To Complete. KOER Aborted.; KOER Test Cannot Be Completed
============40==============
P1101(00)
Raw code: 110100
OBDII: MAF Sensor Out Of Self Test Range
Ford: MAF Sensor Out Of Self Test Range
============41==============
P1116(00)
Raw code: 111600
OBDII: Engine Coolant sensor out of range/ECT Sensor Out Of Self Test Range
Ford: ECT Sensor Out Of Self Test Range; Engine Coolant sensor out of range/ECT Sensor Out Of Self Test Range
============42==============
P1124(00)
Raw code: 112400
OBDII: Throttle Position Sensor Out Of Self Test Range
Ford: TP Sensor Out Of Self Test Range; Throttle Position Sensor Out Of Self Test Range
============43==============
P1127(00)
Raw code: 112700
OBDII: Exhaust Not Warm, Downstream O2 Sensor
Ford: Exhaust Not Warm, Downstream O2 Sensor Not Tester; Exhaust Not Warm, Downstream O2 Sensor
============44==============
P1285(00)
Raw code: 128500
OBDII: Cylinder head over temp sensed
Ford: Cylinder Head Overtemperature Sensed; Cylinder head over temp sensed
============45==============
P1397(00)
Raw code: 139700
OBDII: System Voltage Out Of Self Test Range
Ford: System Voltage Out Of Self Test Range
============46==============
P144A(00)
Raw code: 144A00
Ford: EVAPORATIVE EMISSION (EVAP) SYSTEM PURGE VAPORLINE RESTRICTED / BLOCKED
============47==============
P1450(00)
Raw code: 145000
OBDII: Unable To Bleed Up Fuel Tank Vacuum
Ford: Unable To Bleed Up Fuel Tank Vacuum Edge Products 1080 S. Depot Dr. Ogden, UT 84404 888-360-3343 www.edgeproducts.com Ford DTC Codes 16; Unable To Bleed Up Fuel Tank Vacuum
============48==============
P1464(00)
Raw code: 146400
OBDII: A/C Demand Out of Self Test Range
Ford: A/C Demand Out of Self Test Range
============49==============
P1501(00)
Raw code: 150100
OBDII: Vehicle Speed Sensor Out Of Self Test Range
Ford: Vehicle Speed Sensor Out Of Self Test Range
============50==============
P1575(00)
Raw code: 157500
OBDII: Pedal Position Out of Self Test Range
Ford: Pedal Position Out of Self Test Range
============51==============
P160A(00)
Raw code: 160A00
Ford: CONTROL MODULE VEHICLE OPTIONS RECONFIGURATION ERROR
============52==============
P1703(00)
Raw code: 170300
OBDII: Brake Switch Out Of Self Test Range
Ford: Brake Switch Out Of Self Test Range
============53==============
P1705(00)
Raw code: 170500
OBDII: Not in P or N During KOEO / KOER
Ford: Not in P or N During KOEO / KOER
============54==============
P1709(00)
Raw code: 170900
OBDII: PNP Switch Out Of Self Test Range
Ford: PNP Switch Out Of Self Test Range
============55==============
P219A(00)
Raw code: 219A00
OBDII: Mixture control, bank 1 - value out of range
============56==============
U0104(00)
Raw code: C10400
OBDII: Data bus, cruise control module - no communication
============57==============
U0140(00)
Raw code: C14000
OBDII: Data bus, body control module (BCM) - no communication
============58==============
U0212(00)
Raw code: C21200
OBDII: Data bus, steering column control module - no communication
============59==============
P073E(00)
Raw code: 073E00
OBDII: Transmission system - unable to engage gear reverse
============60==============
P074E(00)
Raw code: 074E00
OBDII: Transmission system - unable to engage gear 6
============61==============
P2787(00)
Raw code: 278700
OBDII: Clutch - temperature too high
============62==============
P2837(00)
Raw code: 283700
OBDII: Transmission shift fork B position - circuit range/performance
============63==============
P0010(00)
Raw code: 001000
============64==============
P0702(00)
Raw code: 070200
============65==============
P07A4(00)
Raw code: 07A400
============66==============
P0882(00)
Raw code: 088200
============67==============
P2701(00)
Raw code: 270100
============68==============
U0101(00)
Raw code: C10100
ECU: ABS/ESP[Archive (inactive)]
Status: Test failed since last DTC clear, Test not completed during this operation cycle
OBDII: Data bus, transmission control module (TCM) - no communication
============69==============
C0040(87)
Raw code: 404087
OBDII: Brake Pedal Switch "A"
============70==============
U0100(00)
Raw code: C10000
OBDII: Data bus, engine control module (ECM) A - no communication
============71==============
U3003(16)
Raw code: F00316
OBDII: Battery voltage
============72==============
B10D7(51)
Raw code: 90D751
ECU: BCM[Archive (inactive)]
============73==============
B10D7(81)
Raw code: 90D781
============74==============
B10D7(94)
Raw code: 90D794
ECU: BCM
Status: Pending, Confirmed, Test failed since last DTC clear, Test not completed during this operation cycle
============75==============
B110A(77)
Raw code: 910A77
============76==============
B1131(87)
Raw code: 913187
============77==============
B11DB(83)
Raw code: 91DB83
============78==============
U0100(00)
Raw code: C10000
============79==============
U0100(87)
Raw code: C10087
============80==============
C111B(15)
Raw code: 511B15
============81==============
C111A(15)
Raw code: 511A15
============82==============
B10E7(14)
Raw code: 90E714
============83==============
B00C2(11)
Raw code: 80C211
ECU: OCS[Archive (inactive)]
OBDII: Passenger Seat Occupant Classification Sensor "C"
============84==============
B0061(11)
Raw code: 806111
OBDII: Passenger Seatbelt Tension Sensor
============85==============
B0061(1C)
Raw code: 80611C
============86==============
U0100(00)
Raw code: C10000
P0010
Raw code: 0010
Status: Confirmed
P0010(00)
Raw code: 001000
P0702(00)
Raw code: 070200
P07A4(00)
Raw code: 07A400
P0882(00)
Raw code: 088200
P2701(00)
Raw code: 270100
P0011(00)
Raw code: 001100
P0012(00)
Raw code: 001200
P0014(00)
Raw code: 001400
P0015(00)
Raw code: 001500
P0016(00)
Raw code: 001600
P0017(00)
Raw code: 001700
P0087(00)
Raw code: 008700
P0088(00)
Raw code: 008800
P0111(00)
Raw code: 011100
P0116(00)
Raw code: 011600
P0128(00)
Raw code: 012800
P0133(00)
Raw code: 013300
P013A(00)
Raw code: 013A00
P013E(00)
Raw code: 013E00
P0217(00)
Raw code: 021700
P0218(00)
Raw code: 021800
P0219(00)
Raw code: 021900
P0297(00)
Raw code: 029700
P0298(00)
Raw code: 029800
P0420(00)
Raw code: 042000
P0442(00)
Raw code: 044200
P0455(00)
Raw code: 045500
P0460(00)
Raw code: 046000
P0505(00)
Raw code: 050500
P050A(00)
Raw code: 050A00
P050B(00)
Raw code: 050B00
P050E(00)
Raw code: 050E00
P052A(00)
Raw code: 052A00
P052B(00)
Raw code: 052B00
P053F(00)
Raw code: 053F00
P0572(00)
Raw code: 057200
P0573(00)
Raw code: 057300
P1001(00)
Raw code: 100100
P1101(00)
Raw code: 110100
P1116(00)
Raw code: 111600
P1124(00)
Raw code: 112400
P1127(00)
Raw code: 112700
P1285(00)
Raw code: 128500
P1397(00)
Raw code: 139700
P144A(00)
Raw code: 144A00
P1450(00)
Raw code: 145000
P1464(00)
Raw code: 146400
P1501(00)
Raw code: 150100
P1575(00)
Raw code: 157500
P160A(00)
Raw code: 160A00
P1703(00)
Raw code: 170300
P1705(00)
Raw code: 170500
P1709(00)
Raw code: 170900
P219A(00)
Raw code: 219A00
U0104(00)
Raw code: C10400
U0140(00)
Raw code: C14000
U0212(00)
Raw code: C21200
P073E(00)
Raw code: 073E00
P074E(00)
Raw code: 074E00
P2787(00)
Raw code: 278700
P2837(00)
Raw code: 283700
P0010(00)
Raw code: 001000
P0702(00)
Raw code: 070200
P07A4(00)
Raw code: 07A400
P0882(00)
Raw code: 088200
P2701(00)
Raw code: 270100
U0101(00)
Raw code: C10100
C0040(87)
Raw code: 404087
U0100(00)
Raw code: C10000
U3003(16)
Raw code: F00316
B10D7(51)
Raw code: 90D751
B10D7(81)
Raw code: 90D781
B10D7(94)
Raw code: 90D794
ECU: BCM
B110A(77)
Raw code: 910A77
B1131(87)
Raw code: 913187
B11DB(83)
Raw code: 91DB83
U0100(00)
Raw code: C10000
U0100(87)
Raw code: C10087
C111B(15)
Raw code: 511B15
C111A(15)
Raw code: 511A15
B10E7(14)
Raw code: 90E714
B00C2(11)
Raw code: 80C211
B0061(11)
Raw code: 806111
B0061(1C)
Raw code: 80611C
U0100(00)
Raw code: C10000
And this vehicle still runs??????????????
Before condemning a PCM, we should check for poor ground connections,
Are there any add on gizmos, They can do things like this.
When we get a load of unrelated codes we look for something they all might have in common and that usually is a ground problem.
Yep, runs and drives, just the rpm's are high. Almost like it's always in the wrong gear? Something to do with timing being off? Timing belt looks fine. Hard to explain. Cruising at 60 is normally around 2.3k rpm but now is at 4k rpm. Just estimates, but that's how it's acting.
No gizmos, nothing aftermarket done to the car at all.
Can't find her paperwork but I'm thinking it was, she bought it at 80k miles and visually the belt looks flawless, car is at 110k now. Bringing it to a shop as we speak to learn more.
Left battery unplugged overnight, still had all the same codes in the morning. Took it to a shop, they also saw all the codes.
Mechanic said that these cars act stupid if the battery voltage dips too low, the car can't communicate with itself properly, and instead of realizing it's because of a dip in voltage it thinks everything else is wrong. Weird because the battery is only 6 months old.
The only code unrelated that he said to see if it comes up again was the camshaft position actuator.
He reset the codes, drives fine, for now.
eallan
Oct 28, 2009 06:10 PM
