2014 Ford Focus Tranny Issue
Old Aug 11, 2023 | 09:19 PM
kjohnson421's Avatar
Default 2014 Ford Focus Tranny Issue
Have a 2014 Ford Focus with the dual clutch design. We were having issues where the car wouldn’t start and was making some weird noises from the clutch actuators. Ended up putting the vehicle in neutral and it started right up. Called a mechanic and they removed actuator A and B and “cleaned” them up and reinstalled them. After that the vehicle was shifting harshly. Had the vehicle towed to a different mechanic and they ordered a rebuilt TCM from JUGS. They suggested replacing the TCM and then pulling the actuators, and then cleaning out clutch forks. Basically, they would run a drill in reverse and spray break cleaner in there a few times, and then after that they would repeat with a lubricant. Apparently during one of these reverses, they went to far and it did recoil back on its own. They’re saying we now must remove the transmission and replace the clutch forks. Does this sound correct?
Old Aug 12, 2023 | 12:36 PM
Do you know if anyone checked the plug on the alternator for loose connections which can set gremlins loose in the vehicle electronics?
remo42
Nov 2, 2023 12:45 PM
Hunter Losey
Oct 5, 2022 03:20 PM
cherylmov
Aug 27, 2017 09:38 PM
FKuga2014
May 1, 2017 02:27 AM
NikjMiles
Jul 20, 2014 10:54 PM
