Brake problems on 2012 Ford Fusion SE
Old Jan 20, 2020 | 04:12 PM
Gary89's Avatar
Default Brake problems on 2012 Ford Fusion SE
I replaced front discs, calipers, and pads. Bled the brakes and pedal still went to floor. Replaced master cylinder. Pedal still went to floor. Hooked it up to scanner and cycled it 5 times. Pedal still went to floor. Hooked it up to a vacuum pump and sucked out more air. Pedal still goes to floor. Suggestions? I'm at my wits end!!
Old Jan 21, 2020 | 06:24 PM
Gary89's Avatar
Help!
Old Jul 11, 2023 | 12:47 PM
Sickvic's Avatar
Default Any update?
Ran into the same problem. Im at my wits end as well.
Old Jul 11, 2023 | 04:13 PM
Did you bench bleed the replacement master cyl before installation?
Old Jul 11, 2023 | 06:49 PM
Sickvic's Avatar
Default Yes…
Bench bleed and the master cylinder was purchased at a dealer. Pedal still goes to the floor. Also changed the abs pump.
Old Jul 12, 2023 | 07:35 AM
Your reply is not clear.
Did you bench the replacement master cyl at the place of installation?
If not, a huge amount of air was injected into the hydraulic system and now has to be removed.
Old Dec 21, 2023 | 06:14 PM
Timothylb's Avatar
Did you ever find the problem? I’m in the same boat. Had a soft pedal so changed the master cylinder bench bled it and ever since the pedal goes to the floor changed the abs pump and hooked a scanner up to bleed and still no pedal even changed back to the old master but still no change, I can’t figure it out!
Old Dec 22, 2023 | 09:17 AM
If the replacement master cyl was not bench bled, you can play all day hoping to get all that air out and waste a lot of good brake fluid.
Every time you get the air close to the exit point you stop and refill the master cyl. .
While doing that the air in the line is working it's way back to the highest point and the cycle repeats.
What you should do is use a pressure brake bleeder that keeps the master full and keeps the pressure constant so it all goes to the exit.. Most folks don't usually have this piece of equip and the job can become a real hassle.There are places in the newer brake systems that trap the air unless constant pressure and valves are kept open to allow the air to exit can be a real challenge.
Brake work today should be left to the places that have the necessary equip and knowledge of what is in the system..
Old Dec 22, 2023 | 09:21 AM
Timothylb's Avatar
the replacement master cylinder was bench bled multiple times but still no luck.
Old Dec 22, 2023 | 11:57 AM
I wouldn't say at this time the master cyl is defective, but more than a few times I have had a few that were not good, .
And we get trapped into that feeling , it can't be the master because I just installed a new one, but it was JUNK.
All I can suggest is ,,,,,,,,,if you know how it is supposed to work and you did everything right and it still had a problem, Yes, it is a bad master cyl.
Something to keep in mind,
If the brake pedal on a present master cyl goes all the way to the floor, plan on replacing it.
Sediment settles in the bore after the normal place it used to stop. Once the rubber cups pass thru that grinding sediment it destroys the sealing capability of the cups and the master cyl is done. Hope this helps solve some of the problem(s).
Fredmy23t
Apr 13, 2019 02:47 PM
Moondoggie
Nov 27, 2015 04:27 PM
frj7a
Feb 27, 2012 09:41 AM
JOHN_T_65202
Jan 3, 2009 01:57 AM
jonas74
Aug 7, 2005 11:25 PM
