Car stalls with A/C at full tank and without A/C at half tank
Old Oct 14, 2018 | 03:45 PM
Chudi's Avatar
Default Car stalls with A/C at full tank and without A/C at half tank
Hi. My 2005 Ford focus hatch back car has fuel transmission issues. When the fuel is gauged at full tank, the car runs perfectly for about an hour with the A/C turned on and then stalls thereafter even while in motion. When I turn the ignition off and on, it works again for 10mins and the same schedule is repeated. Without the A/C, the problem occurs at half tank. The tank stock doesn't go below half else it wouldn't run. I have tried 4 different pumps and changed the filters. I have changed the fuel relay in the engine compartment and the power supply cable. Diagnosis doesn't read any fault. What do you suggest could be the problem?
yankees27
Aug 9, 2012 12:36 PM
two bit okie
Apr 27, 2012 12:15 PM
dotboy2266
Apr 24, 2008 07:21 AM
dadstruck
May 15, 2007 03:23 AM
sprinter
Jan 19, 2007 11:47 PM
