Electric windows not working
Old Sep 6, 2022 | 06:01 AM
johnwin's Avatar
Default Electric windows not working
Ho All,
electric windows not working on either side
see video
https://youtube.com/shorts/Ei2uVmo-l9U?feature=share
have tried replacing fuse 127
its a Ford Focus Zetec 2008 so MK 2
anyone got any ideas how to diagnose and fix?
thanks for any ideas
Old Sep 6, 2022 | 06:18 AM
What I try to do is ,
Remove the window switch assy and with a test light or voltmeter verify power is getting to the sw assy and going out when a function is selected.
Depending on the result obtained will determine where we go from there. Many times there is a broken wire in the driver's door hinge area , and gently pulling on each one can help when you find one that is a little stretchy.
Old Sep 7, 2022 | 08:52 AM
johnwin's Avatar
Thanks!
I gave up and got an electrician out.
He took the door off. Unhooked the door electric plug from the body and found an earth wire had come unstuck from the plug. He secured the wire into the plug and everything is working again
Old Sep 7, 2022 | 01:58 PM
Thank You for the update.
cmoy
Sep 9, 2008 09:43 PM
cmoy
Sep 7, 2008 08:18 PM
kevinjohnson999
Oct 16, 2007 11:37 AM
graven57
Jun 4, 2007 02:42 PM
wv1percenter
Sep 14, 2006 10:22 PM
