no heat
Old 03-03-2017, 03:09 PM
fighter34's Avatar
Default no heat
ok folks ....i have a 2001 ford focus with no to little heat. if you turn heat off for about 5 minutes and then turn back on you have warm air for about 2 minutes then it blows cold air again. the temp is running in the normal range and the fans are running ....the AC has never worked on this car since we bought it..i dont smell antifreeze in the car...any thoughts where to start first
thanks
Old 03-03-2017, 05:38 PM
The symptoms seem to point to a possible restricted heater core. Although a water pump problem may also be in the pix.
Will you be doing the work or will you have someone else do it?
Old 03-05-2017, 10:15 AM
fighter34's Avatar
after she came home and i was able to look at the car ....i found it was down almost a gallon of antifreeze....that fixed the problem, thanks for you feed back hanky
Old 06-25-2017, 04:54 PM
WyrTwister's Avatar
Congrats , glad to see you got it working . But I suggest you try to determing why it was low on coolant ? You may head off worse problems , further down the road .
God bless
Wyr
ricknags
04-05-2019 02:39 PM
Use Common Sense
06-25-2016 01:30 PM
vivalasvegas777
08-29-2012 11:07 AM
joshua.donelson
09-27-2005 08:03 AM
wallygator
09-11-2005 01:08 AM
Quick Reply: no heat
