Random misfire
Old Today | 12:34 PM
g.cristinalavinia@gmail.com's Avatar
Default Random misfire
I have a Ford 1.6 EcoBoost Turbo 150 HP petrol engine. The car started misfiring, and a diagnostic scan showed a random misfire as well as a misfire on cylinder 4. The spark plugs were replaced with new NGK spark plugs. However, after starting the engine, the check engine light came on, and when I turn on the A/C, the engine vibrates very badly.
After running another diagnostic scan, the misfire fault is now showing on cylinder 2 instead. I would like to mention that the ignition coils are installed correctly.
What could be causing this issue?
Old Today | 12:51 PM
What year? And are you in the US/Canada?
Check my signature below.
And which exact scanner are you using?
So you have a check engine light AFTER you changed your spark plugs?
Old Today | 03:51 PM
Did you replace the spark plugs one at a time or all at once doing the same bank?
Easy to mix up 2 wires that look right and yet may not be !
Stvn06
Jul 18, 2025 03:36 PM
Mrg1962
May 22, 2023 12:31 PM
mack369
Feb 4, 2023 03:57 PM
IVANSS
Oct 4, 2022 08:08 AM
Big Lew
Nov 14, 2014 12:33 PM
