SRS Light No Code
Old Sep 20, 2023 | 09:43 AM
Jtdiebs's Avatar
Default SRS Light No Code
So I have had my SRS light on for about a month ago, and had scans dome that will read the codes, and ended up getting no codes. On the dash, it's one flash, pause, then one flash and it stays steady. Haven't found anything for the code it's giving. Any thoughts? Thanks!
Old Sep 20, 2023 | 10:02 AM
Where did you have the check for codes performed?
If the place doesn't have a capable scanner, it can't access any SRS codes..
Old Sep 20, 2023 | 10:12 AM
Jtdiebs's Avatar
I had it done with my my code scanner that will detect any SRS codes. It came back with no codes initially. Now I got it to post code B1932-F0.
Old Sep 20, 2023 | 02:28 PM
Apparently there is an open in the air bag circuit and this is best left to an experienced tech to locate and correct. You would not want to have that air bag go off while you were checking things.
Old Sep 20, 2023 | 02:57 PM
Jtdiebs's Avatar
I'm about at that point. If it's one thing I won't work on my car, it's that. But it does seem to actually line up another issue I posted about as well with my trunk not opening unless the wiper is activated. The light and wiper/trunk issue was very on and off, but now it's on all the time, along with my wiper situation.
Old Sep 26, 2023 | 03:00 PM
Jtdiebs's Avatar
So I did fix the code. All I had to do was remove the airbag, and then apply dielectric grease to the connectors, and fixed it. Code is not appearing again, so I'm Glad it was that "simple".
tlkenn
Jan 11, 2009 09:13 PM
mexiburger
Jan 30, 2008 08:49 AM
bugzred
Nov 10, 2007 11:03 AM
Ranger96
Oct 26, 2006 06:26 PM
wandadecatur
Sep 3, 2006 08:11 PM
