airbag light on
Old Nov 28, 2007 | 12:08 PM
tlkenn's Avatar
Default airbag light on
I have a 2002 escape with 84,000 miles on. The car is driving fine but the airbag light randomly started blinking and then just stayed on. any help?
Old Nov 28, 2007 | 01:13 PM
BRETM's Avatar
Default RE: airbag light on
Can you tell what the light flash code is? Just turn the key to the ON position, then the light will come on, then start flashing, pause, then flash again. Count the number of flashes for the first set, then the other set after the pause and it should give you a two digit code. Let me know.
Old Dec 18, 2007 | 07:17 AM
tlkenn's Avatar
It went off for a while right after i posted last time. Now it comes on after i've been driving about 15 minutes and when if i get on the break hard it will flash a few times or just stays on. I'll look and count the number of times it flashes though. What could the codes mean?
Old Dec 20, 2007 | 10:35 AM
BRETM's Avatar
Need to know what the light flash code is to be of any more help.
Old Jan 11, 2009 | 09:13 PM
battnotincluded30's Avatar
I have a 2004 and have the same problem.I work in a shop and it doesn't blink the codes only late model Chevys.If you hit your brake and it came on it probably is the same thing with mine.The airbag sensor in the driverside quartar panel is bad.
henryts77
May 15, 2014 11:04 AM
sshupe
Oct 12, 2005 02:12 PM
ctsanders
Aug 22, 2005 06:32 PM
butters417
Apr 2, 2005 01:52 PM
butters417
Mar 20, 2005 10:57 PM
