Turn signal dont work
Sorry Sir I am a newbie, well its a 2002 ford focus ZX3 I think I blew a fuse or relay my turn and hazard doesnt work I hear it cliking inside but the acctual light doesnt come on also my brake lights are not getting brighter when i step on the brakes just the third brake light turns on. My manual is vaige I am not sure wut fuse or relay to check or how to check to see if a relay is bad thanks
Not a problem,
Since the High Mount brake light still works, that should eliminate the fuse and the stoplight switch .. Could be a problem in the multifunction switch, or the turn/stops functions are run through the GEM module.. Fuses for turns/stops are #32/15amp and 42/15amp..
Glowbug
Jan 28, 2022 12:43 PM
broncocarnage
Dec 11, 2007 12:07 PM
