‘02 F-150, right rear locking up
Old Jul 5, 2025 | 04:35 PM
Trooperdoon's Avatar
Default ‘02 F-150, right rear locking up
The right rear wheel of my ‘02 F-150 is locking up.
Is there a problem with my emergency brake?
Old Jul 5, 2025 | 06:34 PM
Because both use some of the same parts to work, the only way to know for sure which is causing the problem, the wheel needs to be removed and the brake parts actually checked.
Grease or brake fluid getting on the friction parts can cause the wheel to lock up on brake application, so can broken brake hardware..Requires visual inspection to determine the exact cause.
Old Jul 5, 2025 | 06:52 PM
Check my signature below. Additionally what's the 8th character of your VIN.
Also why you think there is a problem with your parking brake. Anything wrong with your red brake light?
Old Jul 6, 2025 | 08:49 AM
Default Looking for…
What should look for?
Old Jul 6, 2025 | 11:28 AM
Anything like grease ,oil or brake fluid on pads or brake shoes, also the parts that secure the shoes to the backing plate.
That should give you plenty to check..
petertom
Apr 7, 2024 02:38 AM
jayrobsand2002
May 25, 2022 03:27 PM
ILoveTheWoods
Oct 24, 2021 08:01 PM
ksz15511
Nov 24, 2019 04:11 PM
87facelift
Mar 12, 2010 03:18 PM
