2004 E150 No brake light and no turn lights
My brake light, turn lights and flasher stops working all at the same time. I did some research and suggested to check the multifunction switch. After checking all the fuses, I also replaced the multifunction switch but the problem still NOT fix.
Now I am trying to check the flasher/relay but I can find it. Can someone please show me where can I find it. Also if you had similar problem in the past, how did you fix it ?
Thank you in advance!
Eric
Eric
You said 2004 E150, 4.6L or 5.4L (check my signature below).
Both brake and turn signal lamps all stopped working at the same time?
You ever upgraded to LED bulbs?
On my 98 E150 4.2L the flasher relay is between the under steering column fuse box and brake switch.
Please don't throw parts at it, it takes just a multimeter to diagnose the problem.
Thanks!
Thank you! I found the relay. Tested it and it is fine.
Liv Rose
Jul 6, 2021 09:35 AM
benb81
Jan 7, 2017 02:27 AM
