2004 Ford F-250 Super Duty 5.4L V8 Humming / Foghorn
Old Dec 4, 2024 | 12:11 AM
MilitaryAndTrucks's Avatar
Default 2004 Ford F-250 Super Duty 5.4L V8 Humming / Foghorn
Hi everyone,
I’m having an issue with my 2004 Ford F-250 Super Duty (5.4L V8). There’s a humming / foghorn noise coming from the front of the air intake system, specifically near the air filter housing. Here are the details:
1. When It Happens:
The noise occurs at low speeds (around 1–10 mph) or when the truck is idling.
It can also happen at higher speeds (e.g., 35 mph) when I let off the accelerator or lightly flutter the gas pedal.
It doesn’t happen all the time and is more likely to occur after the truck has been driven for a while.
The noise seems worse in colder weather but can also happen in warmer conditions.
2. When It Stops:
The noise immediately stops if I raise the RPMs above idle or turn off the truck.
If I raise the RPMs before coming to a stop sign or slowing down, the noise is less likely to happen.
3. Challenges Diagnosing the Issue:
The noise doesn’t always occur. For example, I took it to the mechanic twice, and both times the noise didn’t happen, so they couldn’t determine what’s causing it.
The truck does not stall during or after the noise occurs.
4. What I’ve Tried:
I’ve inspected the air filter, which appears to be seated correctly and is clean.
I also ensured the air filter housing retention was tight and tried loosening it slightly to see if it made a difference, but there was no change.
I’ve searched the web and these forums for similar issues. The closest suggestions I found were related to the Idle Air Control (IAC) valve and the PCV valve. However:
The IAC valve is located further back on the engine, so it doesn’t seem to match where I’m hearing the noise.
The PCV valve is on the passenger side, whereas the noise I’m hearing is at the very front of the truck, on the driver’s side, right in front of the air intake/air filter.
Has anyone experienced a similar issue or have ideas on what might be causing this? Any help or suggestions would be greatly appreciated!
Thanks in advance my friends.
Old Dec 4, 2024 | 11:54 AM
Try running the engine in place without the air filter. There is no silver bullet for this type problem and the process of elimination usually works..
Old Dec 4, 2024 | 02:11 PM
I've been having a really hard time trying to activate whenever in park or netrual and revving the engine.
Seems to really like to do it when I'm driving at around 1200 RPM and then let off the throttle.
Old Dec 4, 2024 | 06:30 PM
What happens when you let off the throttle, vacuum goes high. The area that is under that higher vacuum should be after the throttle body and all vacuum supplied components and the intake manifold.
There is usually a vacuum diagram in the engine compartment showing the hose routing and components involved.
That might be a good place to start looking for something loose that will flutter with strong vacuum applied.
Old Dec 11, 2024 | 12:38 PM
Do you think it can be the Fuel Vapor Canister?
I went to go pickup my car today for an oil change and while I was driving to the mechanic shop in my truck, luckily as I was pulling in, the noise activated and I stopped the truck real fast and ran inside to see if my mechanic can grab his stethoscope and find the issue.
So far he said he heard the noise closest to the Abs Pump / a cylinder component which he didn't know what it was, but I just found out it's called the Fuel Vapor Canister. Do you think this could be my issue based on your explanation?
Old Dec 11, 2024 | 02:54 PM
If it has a vacuum line going to it , disconnect the vacuum line and plug it. you may get a check engine light. If the noise goes away, we go from there..
Pete C
Apr 19, 2024 03:02 PM
GearSpeedKelvo
Oct 19, 2013 10:48 AM
J_o_s_h
Jun 19, 2012 08:05 PM
Phil O
Aug 24, 2011 07:59 AM
rusty jones
Mar 9, 2011 02:47 AM
