2004 Ford Freestar Transmission
Old Feb 16, 2022 | 10:17 PM
Melanie1964's Avatar
Default 2004 Ford Freestar Transmission
A smooth shift going from park to drive, shift hards going into 2 & 3, and shifts smooth going into OD. But can't go from Drive to Reverse it stutters. But if you put it in Park and then drop it into reverse it's fine. Checked the fluid regularly and it's fine. Someone said it could be the computer picked up on different drivers. My husband was a drive it like you stole it driver and I'm more of a driving Ms. Dasiy driver. When I disconnected the battery. The check engine light went off and it seemed fine for awhile and then started again.
Any Ideas?
Old Feb 17, 2022 | 04:10 AM
raski's Avatar
Those mini vans were plagued with transmission issues. Mostly failed torque converters which there was a recall on them long ago. When I had one fail, the vehicle wouldn't move. Is the OD light flashing? I would atleast start with a code reading to see what the computer does not like. There may be an issue with a shift solenoid.
Taking into consideration the history of these transmissions, I got a feeling that you are in for a major repair or replacement of the transmission. Probably wouldn't hurt to drop the pan to see if there is any unusual debris in the pan and replace the filter. By examining what is on the pan's bottom could confirm the need for a rebuild or replacement.
Old Feb 17, 2022 | 09:18 AM
I did have the torque converter replaced when it was recalled. I’ve already said if they say I need a new transmission I will just drive it till it dies. I’m not putting a $2000 transmission in an 04 Freestar thats worth maybe $1800. It’s just not worth it. I found a coupon to have Aamco put it on the computer for free. I might just take them up on that.
Old Feb 17, 2022 | 09:36 AM
The wise thing to do would be to get a few different estimates.
If you feel the vehicle is not worth much to you consider unloading it before spending any $$ on it
The only problem then becomes if you purchase another used vehicle , we never know why that vehicle was traded.
If you can afford it , of course a new vehicle would be just fine. Only you know what kind of maintenance your vehicle has received and if that is the only problem it might be worth considering having it repaired.
Old Feb 18, 2022 | 09:03 AM
raski's Avatar
^ ^ Very sound advice for your transmission.
edripz
Jul 14, 2021 02:05 PM
saltflat
Jul 23, 2014 01:43 PM
jjames1967
Jun 6, 2012 12:01 AM
jjvb2003
Mar 30, 2011 08:26 PM
toaster
Jul 17, 2005 03:19 PM
