2011 ford escape
Old Oct 2, 2020 | 09:40 AM
Justman123's Avatar
Default 2011 ford escape
i have a 2011 ford escape 3.0 AWD limited and i am having some front end noise. I have had the sway bar links changed, i just did the control arms, and i changed a strut on the driver side, However i am still getting a clunking sound on both sides in the front end when i hit bumps, i live on rougb country roads and i am getting frustrated with the trial and error process lol. Any help or opinions would be awesome. Cheers
Edit
Old Oct 2, 2020 | 06:55 PM
scott.butler4's Avatar
Does it matter if you are turning left or right for the bumping noise, are you sure its the front and not the rear, does it sound like it coming more from left or right? Ive seen many engine mounts start to go out and sound/feel like bad struts.
To me it sounds like you should get the vehicle on a lift with the suspension at ride height, like a alignment rack, then take a prybar though everything to check for movement and clunking.
Old Oct 2, 2020 | 11:14 PM
Justman123's Avatar
does not matter turning left or right, only happens when i am hitting bumps and it really sounds like its coming from front end. Might be my mind playing tricks on me but im sure i can feel it at my feet when its making the clunking sound. I was told to change the strut mounts and the front to frame sway-bar bushings
Old Oct 2, 2020 | 11:22 PM
Generally strut mounts indicate they are bad by making noise when the wheel is turned side to side, I dont know how to describe the noise sorry.
Not a bad idea to look at sway bar bushings, this is easy to check when the vehicke is in the air with the wheels/suspension at ride height, usually you can look for paint rubbed off the sway bar if the bushings are shoot.
Old Oct 14, 2020 | 12:20 PM
Justman123's Avatar
ended up being the sway bar bushings, never woulda thought it would create such a nasty loud knocking, next up is rear wheel bearing :/ lol
thanks for your help cheers
Beware 2013 Escape LEMON!
Mar 8, 2019 09:35 AM
renatosc123
Jan 7, 2012 02:17 PM
texastiger
Sep 26, 2007 07:46 PM
T.M.
Aug 29, 2007 01:37 AM
moose
Jul 4, 2007 02:53 PM
