2011 Ford ranger xl 2.3l 2 wheel drive
Old May 18, 2023 | 06:59 AM
J.elliott's Avatar
Default 2011 Ford ranger xl 2.3l 2 wheel drive
Where is the transmission shift solenoid in the tranny pan
Old May 18, 2023 | 11:28 AM
You must have a reason for asking. There are several shift solenoids and you need to know which one you are after.
A word of caution, however, just because a code might suggest a particular possible solenoid problem does not necessarily mean the solenoid is defective.
You need to verify all connections are good and clean and the solenoid is getting the signal to operate or you could go through a lot of trouble and work only to still have the same problem
Richard J
Sep 1, 2019 07:49 PM
bobbyp70
Jul 26, 2016 08:45 PM
hunter99
Jan 8, 2012 07:32 PM
renatosc123
Jan 7, 2012 02:17 PM
