melted the battery cable
Old 06-10-2013, 10:19 PM
fordborn's Avatar
Default melted the battery cable
79 400m now has an ignition switch problem...stuck to on position..Before this happened the battery cable would get real hot ,real fast, while cranking. Wondering what things can cause this. ( battery cable hottest right at solinoid connection).
Anybody know what makes the cable hot??
ok I replaced the starter ..it checked to be burnt up probably was turning hard and drawing lots of amps thus all the heat ..starter wontr stop ..only way to stop it is to remove battery cable...guessing switch is defective ( key) but it wasent before could all the cranking I hax to do cause the switch to bad???
jdmchugh
02-23-2015 05:38 AM
teleman
10-25-2013 05:31 AM
bobbythomas
06-25-2013 02:06 PM
programguru
08-27-2009 12:16 AM
Teal Mobile
10-22-2007 10:35 PM
Quick Reply: melted the battery cable
