Ford Bronco One of the original SUVs, offered in both a full size Bronco, or the more compact Bronco II.
Disconnect Negative Battery Cable (only needed in one location)
Old Aug 26, 2009 | 04:26 PM
programguru's Avatar
Question Disconnect Negative Battery Cable (only needed in one location)
When working on power areas of my truck, is it only necessary to remove the Negative battery cable from my battery?
I don't want any current running through my engine at all.
I'm planning to change my fuel pump, and I just want to make sure that is the only place it would need to be disconnected - any other tips welcome.
Thanks in advance.
Old Aug 27, 2009 | 12:06 AM
Pulling the negative cable would be fine.. Make sure it's tucked away/secured to the side so it can't spring back and make a contact...
Old Aug 27, 2009 | 12:16 AM
Nice thanks for the insight...
teleman
Oct 25, 2013 05:31 AM
CFord02
Mar 16, 2012 07:46 PM
rlevy64614
Aug 7, 2008 10:40 PM
HAWGJO
Apr 19, 2007 07:48 AM
bassfisher
Jan 6, 2006 04:20 PM
