2001 ZX2 negative battery cable
Old Oct 24, 2013 | 10:32 PM
teleman's Avatar
Default 2001 ZX2 negative battery cable
Hi. New here. Maybe someone's seen this problem before, I hope. I've got a 2001 ZX2 (auto trans). We discovered a grounding problem. My buddy suggested running a new ground from engine block or trans. to chassis, to override the fault. I''ll probably do that, but...what's up with the nagative battery cable on these? When I replaced my battery a few months ago I found the terminal all corroded. And it had several smaller wires along with the main neg. wire leading into the terminal connector. I cleaned it up real good. It looked to me like something that need to be replaced, but no one seems to sell them, other than Ford, if you want to buy a whole new engine wiring thing for several hundred dollars just to get a battery connector. Or get one from a junkyard that is also old. A few months later, corrosion is reappearing, and we've got a ground problem. So my question...can I just use a standard negative battery cable and connector, and take these other wires and run them all to a singe ground point, either on the chassis or the neg. battery terminal like they seem to go to now?
Old Oct 25, 2013 | 05:31 AM
Yes , you can. If you use 10 gauge wire and the proper terminals = more than sufficient to do the job.
fordborn
Jun 10, 2013 10:19 PM
CFord02
Mar 16, 2012 07:46 PM
programguru
Aug 27, 2009 12:16 AM
rlevy64614
Aug 7, 2008 10:40 PM
Teal Mobile
Oct 22, 2007 10:35 PM
