93 f-150 needs help
Old Nov 8, 2014 | 07:39 AM
brian6410's Avatar
Default 93 f-150 needs help
302 motor/ getting blow by out of the oil fill vent hose/smoking really bad at high speeds out of hose/ changed out pvc valve already/ not sure what to do next?? can anyone help me??? Motor is still very strong miles on truck is 137,000
Old Nov 8, 2014 | 08:13 AM
You didn't provide any mileage info which could help answer your question, however, so you know where you stand it would be a good idea to run a compression test. Based on those results your next steps might be to pursue the remaining possibilities. In either case it appears compression is getting into the crankcase and it could be from one or more cylinders with worn/ stuck piston rings. Let us know what the readings were for each of the 8 cyls.
f150harley06
Sep 26, 2006 11:22 PM
yellowjacket94
Aug 7, 2006 02:32 AM
The Green Monster
Apr 22, 2006 02:06 PM
Vanster
Feb 22, 2006 02:05 AM
kazalex
Jan 13, 2006 08:34 PM
