96 F350 rear brakes uncommanded actuating
Old Nov 12, 2022 | 01:32 PM
PWRmx24's Avatar
Default 96 F350 rear brakes uncommanded actuating
Rear brakes are hot.....starting smoking.
Obviously I wasn't applying the brakes.
Bad ABS model? Bad rear axle sensor?
Problem right now is I have 800 miles to go today/tomorrow. Can I/should I disconnect the ABS somehow? How to do that?
Old Nov 12, 2022 | 03:00 PM
If you applied the parking brake , and don't use it much, the cables could be stuck and partially applying the rear brakes.
If you pull the ABS fuse, they can't apply/release, so that would get rid of that if it is the cause.
If you get under your vehicle and look at the rear brake cables, they should not be taut, but have some slack. If tight, they are stuck and most times you need to remove the drum to pull the sticking cables back to completely release the tension on the shoes.
Old Nov 12, 2022 | 03:15 PM
PWRmx24's Avatar
Pulled #15 fuze in the cabin. ABS light on. Brakes still hot. Parking cable loose enough for me to disconnect by hand...so I did. Trying that now. One iNet source showed engine compartment relay 5 was ABS pump. But truck wouldn't start with that pulled.
Old Nov 12, 2022 | 03:35 PM
PWRmx24's Avatar
Thanks for the reply...still hot. Not smoking but hot to the touch still....
Old Nov 12, 2022 | 03:48 PM
PWRmx24's Avatar
Let me back up here a bit.... yesterday the truck was off and no key in it. The truck brake light came on. All by themselves. Truck wasn't running and no one was in it. I thought.....bad brake controller or bad ABS. It wasn't hooked to a trailer.
Old Nov 12, 2022 | 04:21 PM
PWRmx24's Avatar
Yeah......still hot. Driving 50 mph.
Old Nov 12, 2022 | 04:37 PM
PWRmx24's Avatar
Maybe the auto adjuster is overtighing
Old Nov 12, 2022 | 06:14 PM
Should have asked this earlier.
One wheel or both?
Have had only one instance where adjuster over adjusted, very possible
If only one wheel, you probably will need to remove the drum and do a visual inspection because something is going on there.
If there is a broken return spring , a shoe could be dragging.
Old Nov 12, 2022 | 07:27 PM
PWRmx24's Avatar
Passenger rear is worse but the driver rear is hot too.
Old Nov 13, 2022 | 04:29 AM
Did anybody do any work on the hydraulic system like replace the master cyl or any other brake work?
