97 3.0 Windstar transmission pan metal hoses
Old May 3, 2020 | 06:29 PM
Fred Palazzo's Avatar
Default 97 3.0 Windstar transmission pan metal hoses
I took off the transmission pan to change the filter and one of the metal hoses inside was very loose. I could push the outside end on easily but cannot get the inside end to go in all the way. Do I need to put the car in a special gear or neutral to get the line seated? Thanks in advance
Old May 4, 2020 | 11:46 AM
If you have the trans with the 5 tubes, there should be 2 brackets that hold them in place. When installing the tubes , tap them lightly until fully seated.
If this was an overhaul, you would use a thread locker between the tube and case.
Some have the clamp that holds the reverse tube and trans oil filter in place.
Old May 4, 2020 | 08:05 PM
Default Hoses
Yes. I loosened the bracket, and checked the hole that the longer end goes into. It's all clear and a skinny screwdriver can travel as far as the tube needs to go. But when I insert it, it stops about half an inch too soon to seat properly. I tried twisting the metal tube while pushing it. Tapping it with a plastic mallet while twisting it, but it won't go all the way. I almost want to cut half an inch of tube off. Do I just need to keep at it? Nothing special for what gear I'm in, etc. But thank you for answering.
Old May 5, 2020 | 04:29 AM
If they were in there previously, they should go back in there.Should not need to us any excessive force.
Exactly which tube is giving you the problem ?
lizlang@ptd.net
Sep 11, 2016 11:56 AM
bobepan
Feb 17, 2014 12:24 AM
fredhead
May 8, 2013 06:04 PM
Cher1963
Aug 18, 2011 01:31 PM
steinsteve
Apr 25, 2006 11:26 PM
