C4 automatic transmission
Old Oct 22, 2024 | 01:39 PM
Steve Wernsman's Avatar
Default C4 automatic transmission
my C4 transmission leaks transmission fluid around the bell housing area after sitting for a week or two but shifts fine...what could be leaking?
Old Oct 22, 2024 | 02:46 PM
Leaking from the bell housing area, if tranny fluid, then torque converter, if engine oil then rear main seal, if coolant then freeze plug or water pump/tstat.
Old Oct 22, 2024 | 03:29 PM
its a 289 ci ford in a 40 merc convertible
Old Oct 22, 2024 | 07:39 PM
There is a front trans seal where the torque converter indexes with the front pump. If the bushing in the pump housing is worn it will also destroy the seal..
Many times just replacing the front seal is enough to correct the leak. Trans has to come out and converter removed to replace seal. Not that difficult to replace that seal.
petertom
May 15, 2021 02:54 AM
jjames1967
Jun 6, 2012 12:01 AM
Jonzo
Apr 30, 2008 10:38 AM
Jonzo
Apr 30, 2008 10:37 AM
crown1969
Nov 25, 2007 02:15 PM
