Engine swap
Old Apr 18, 2018 | 06:48 AM
Mikei's Avatar
Default Engine swap
I have a 2002 f150 it currently has a 4.6 engine , which needs to be replaced, my question is will a 5.4 engine swap work? Would all of the sensors be the same and the original 4.6 computer work with the 5.4,,, is there anything I would have to add or replace electronics wise ?.
Old Apr 19, 2018 | 03:06 PM
Thumbs up
Welcome to the site..
A swap would certainly be possible, but as far as a direct install, No.. Considering all the engine management pieces, build specific hardware, cost may play the upper hand unless a bigger displacement is the goal. When doing a swap, generally if you can find a donor it makes for a better/easier task, and costs are somewhere in reality..
bmwrocks03
Apr 21, 2008 09:29 PM
matt95ssei
Apr 5, 2008 02:15 PM
F 150 Bama
Aug 20, 2005 02:06 AM
92FlareSide
Jul 1, 2005 02:30 PM
fordmann67
May 8, 2005 09:22 PM
