fixed a p307 and got a p308 later in the day
Old Sep 30, 2020 | 12:44 PM
titanfan's Avatar
Default fixed a p307 and got a p308 later in the day
Hey guys I need a little help with a 2012 Expedition 8cyl,. I was throwing a code po307 the check engine light has been coming on under hard acceleration but then going off after about 30 seconds of letting up on the accelerator.
I replaced the coil on cylinder 7 and the first time I was able to accelerate hard the check engine light stopped coming on. The same day It did it again and it was back.
This time I get a p0308 code.
Could just be another coil but seemed odd. I have 130000 miles on it.
Any ideas?
Thanks
Tony
Old Sep 30, 2020 | 04:05 PM
scott.butler4's Avatar
Clear the code and see what happens, assuming a P030X code comes back, number the coils and swap the coil with the fault code with another cylinders coil. Clear the code again and see what code come back.
Have you done a tune up recently.
Old Sep 30, 2020 | 04:31 PM
titanfan's Avatar
Thanks Scott
Thats a good idea. I bought the vehicle 3 months ago and dont know when the last tune up was. I planned on pulling the plugs in the spring but I may go ahead and do that now. Just seemed odd that the code moved up 1 cylinder on the day I fixed number 7 lol
Old Oct 1, 2020 | 05:55 AM
raski's Avatar
I would replace plugs along with COP's. Widened gaps from worn plugs will make the coils work harder, increasing the stress on them. Ignition parts many times will break down under stress like accelerating. Use only Motorcraft coils and not aftermarket ones.
In rare situations, a fuel injector can also set up a misfire code and can be swapped like a coil to troubleshoot.
Old Oct 1, 2020 | 08:41 AM
Don't feel badly. Fords for some reason on some earlier models had a problem indicating which cyl actually was misfiring and threw the wrong cyl number.
If you decide to switch coils, switch with a coli from the other bank and not next to the cyl in the firing order.
skip1930
Feb 12, 2023 07:47 AM
Nwong92
Dec 22, 2019 04:05 PM
skip1930
Jan 26, 2013 04:56 PM
fire0629
May 20, 2008 12:54 PM
