ford fiest 2013
Old Feb 26, 2022 | 11:30 AM
steeveb1's Avatar
Exclamation ford fiest 2013
I have a 2013 ford fiesta and I am trying to locat the input seed sensor can anyone tell me where can I find it?
thank you.
Old Feb 26, 2022 | 11:17 PM
scott.butler4's Avatar
There are two input speed sensors. Do you have any fault codes to show which sensor it is.
Old Feb 27, 2022 | 04:28 AM
steeveb1's Avatar
yes. p0715 turbine/input shaft speed sensor circuit
Old Feb 28, 2022 | 06:32 AM
PINPOINT TEST D : INPUT SHAFT SPEED SENSOR 1 OR 2 FAULT
D1 READ AND RECORD ALL DTCS
Connect the scan tool.
Using the diagnostic scan tool, retrieve all DTCs .
Are ISS sensor 1 and 2 DTCs present?
Yes For DTCs P06A6, P0715, P0716, P0717 and/or P0718, GO to D2. For DTCs P06A7, P2765, P2766, P2767 and/or P2768, GO to D6.
No PERFORM the Speed Sensor Test, REFER to Transmission Adaptive Learning.
D2 CHECK THE ISS SENSOR 1 POWER CIRCUIT FOR VOLTAGE
Ignition OFF.
Disconnect: ISS Sensor C143 .
Inspect the connectors for damaged or pushed-out terminals, corrosion, loose wires and missing or damaged seals.
Ignition ON.
Measure the voltage between:
Positive Lead Negative Lead
Pin Circuit Pin Circuit
C143-2 — — Ground
Is the voltage greater than 10.5 volts?
Yes GO to D3.
No GO to D4.
D3 CHECK THE ISS SENSOR 1 RETURN CIRCUIT
C143-1 — C143-2 —
Yes INSTALL a new ISS sensor 1. REFER to Input Shaft Speed Sensor — No. 1. PERFORM the Speed Sensor Test, REFER to Transmission Adaptive Learning.
No GO to D4.
D4 CHECK THE ISS SENSOR 1 CIRCUITS FOR AN OPEN
Ignition OFF.
Disconnect: TCM C1750B .
Measure resistance between:
C143-1 — C1750B-10 —
C143-2 — C1750B-21 —
Are the resistances less than 5 ohms?
Yes GO to D5.
No REPAIR the circuit.
D5 CHECK THE ISS SENSOR 1 CIRCUITS FOR A SHORT TO GROUND
Measure the resistance between:
C143-1 — — Ground
C143-2 — — Ground
Are the resistances greater than 10,000 ohms?
No INSPECT and REPAIR the circuit shorted to ground. If a short to ground was not found, INSTALL a new TCM . REFER to Transmission Control Module (TCM). PROGRAM the TCM with the latest calibration, REFER to Transmission Adaptive Learning.
D6 CHECK THE ISS SENSOR 2 POWER CIRCUIT FOR VOLTAGE
Ignition OFF.
Disconnect: ISS Sensor 2 C164 .
Ignition ON.
C164-1 — — Ground
Yes GO to D7.
No GO to D8.
D7 CHECK THE ISS SENSOR 2 RETURN CIRCUIT
C164-1 — C164-2 —
Yes INSTALL a new ISS sensor 2. REFER to Clutch Motor — No. 2. PERFORM the Speed Sensor Test, REFER to Transmission Adaptive Learning.
No GO to D8.
D8 CHECK THE ISS SENSOR 2 CIRCUITS FOR AN OPEN
Ignition OFF.
C164-1 — C1750B-12 —
C164-2 — C1750B-8 —
Yes GO to D9.
D9 CHECK THE ISS SENSOR 2 CIRCUITS FOR A SHORT TO GROUND
C164-1 — — Ground
C164-2 — — Ground
Old Feb 28, 2022 | 06:33 AM
Connector Views.
Attached Thumbnails ford fiest 2013-1.png   ford fiest 2013-2.png   ford fiest 2013-3.png
Beware 2013 Escape LEMON!
Mar 8, 2019 09:35 AM
csearing
Nov 2, 2013 10:53 PM
renatosc123
Sep 15, 2013 04:08 AM
brhaminator
Jun 14, 2013 04:11 PM
