help
Old Jan 19, 2012 | 05:14 PM
dozerdan@zoomtown.com's Avatar
Angry help
2000 excursion 4x4 hubs won't lock in
Old Jan 20, 2012 | 01:17 AM
blazz81's Avatar
Replace the hub the condition you have is caused by corrosion of the hub body. Your hub should have 2 positions lock and auto. The auto system is operated by vacuum and trying to fix that hub can cause a vacuum leak making the auto system inop. It is simple to change just remove your center cap and squeeze the 2 tangs of the snap ring and pull out. Hope this helps
Old Jan 21, 2012 | 09:42 AM
thanks i'll try that
jd637
Feb 22, 2019 08:14 AM
jborushko
Dec 22, 2016 08:06 PM
