How do you get the steering wheel off!?!
Old Mar 31, 2012 | 03:02 PM
Shttybill's Avatar
Default How do you get the steering wheel off!?!
i have a 1977 Ford F150 and i need to know how to get the steering wheel off. the steering wheel it has on is cracked and split and i want to put a new one on in replace of this one.
Old Mar 31, 2012 | 05:32 PM
Since no one has answered your post so far I will take a shot at it.
The first thing to do would be to disconnect the negative battery cable from the battery.
Next , This goes back some so I could be incorrect relying only on memory.
Depress the horn button and rotate it counterclockwise until it comes up (about a quarter turn).
Then you should see the plate with the horn contact wire that you can remove to gain access to the steering shaft nut.
The plate may be held down to the steering wheel with three screws which you need to remove.
Now you have access to the nut that holds the steering wheel to the steering shaft.
Take a center punch and place a punch mark on the steering wheel and one on the steering shaft so when it comes time to reassemble it , it goes back together the same way.
Remove the nut or if you don't have a steering wheel puller back the nut off until it is flush with the shaft. Place your knees under the steering wheel and while pushing the wheel up give one good rap on the nut with a hammer. The steering wheel should pop up from being jammed on the splines of the steering shaft. Now you can remove the nut and there should be no damage to the steering shaft. Off comes the steering wheel ! Boy I hope these directions are OK, its been a while since WOW a 1977 ??
Old Mar 31, 2012 | 11:27 PM
Shttybill's Avatar
Thanks man! and yea, a 77! Got it for $500. pretty damn good deal for a running F150 from 77 and 3 on the tree manual! i cant wait to get it on the road once im done restoring it!
Old Mar 31, 2012 | 11:53 PM
Keep us informed with some pix. Thanks
Old Apr 1, 2012 | 11:17 AM
77 has the 'wing' style rubber horn contact. Should be 2 screws on the back side of the steering wheel. 1 on each side..
Old Apr 1, 2012 | 11:34 AM
Thanks Hayapower, I probably went too far back !
Old Apr 1, 2012 | 11:38 AM
Shttybill's Avatar
The build and pictures will be on this thread: https://www.fordforum.com/forum/ford...rebuild-26821/
Old Apr 1, 2012 | 11:58 PM
Was only 35 years ago, I'm just glad we can still remember
Old Apr 2, 2012 | 12:03 AM
Looks like a pretty good deal if it runs well.
70's was some of Ford's best iron. Worked on 'many' of them. Sure would like to find one here for my property as a work wagon. We'll keep an eye on your progress. I just started a resto on my 69 T/A as well..
nmdoc
May 15, 2014 11:49 AM
PostRelease
Jul 30, 2010 09:30 PM
PostRelease
Chirp54
May 18, 2010 12:29 PM
