1998 Ford Ranger
Old 07-20-2018, 11:15 PM
NickJewy's Avatar
Default 1998 Ford Ranger
I just bought this Ford Ranger a week ago and it seems very difficult to down shift into 2nd and 1st gear is much harder. Just today while downshifting into first the clutch was engaged and my gears grinded. What could this possibly be? I've driven stick before but I'm no expert. And help would be greatly appreciated!
Old 07-21-2018, 02:38 PM
Most stick shift transmissions for automobiles have synchronizers that will get the gears in the trans at the same speed as the engine for "grindless" shifting.
They are called blocking rings and are usually made with a brass alloy. Sometimes these blocking rings wear or split and don't do their job and have to be replaced.
If that is the case , trans removal is required and disassembly in order to replace those blocking rings. The hardest part is removing and installing the trans.
I believe your vehicle may have a hydraulic clutch system, make sure the clutch master cyl is full and working correctly.
petehack
07-06-2018 07:41 PM
Tony Remo
01-15-2013 07:33 PM
boogiesan
06-05-2010 10:40 PM
nickstruck
10-17-2008 03:43 PM
fsds123
06-07-2006 01:17 PM
Quick Reply: 1998 Ford Ranger
