Putting a v8 from an 88 F150 into a 93
Old Apr 27, 2018 | 11:31 PM
Rob Fines's Avatar
Default Putting a v8 from an 88 F150 into a 93
So I have to replace my 5.0L 302 V8 in my 1993 F150. I found a donor engine in an 1988 F150, also an EFI 5.0 L. I was wondering if anyone sees any issues putting an engine from an 88 into a 93
Old Apr 28, 2018 | 04:41 AM
Sometimes it a good idea to get the whole picture before offering suggestions.
Soooo,,,,
What went wrong with the orig engine from the 93?
The 302s did have some problems with soft valve guides and miles on the engines are a consideration.
Can you bring us up to speed on what happened?
Sometimes another point of view helps.
Old Apr 28, 2018 | 12:20 PM
Rob Fines's Avatar
I haven’t had a chance to inspect the damage as I was on vacation when it happened but I am told a receiving rod seized and then proceeded to project itself through the oil pan. I guess oil was everywhere
the ford technician said it would make more sense to replace the engine than fix it, but I plan on inspecting the engine when I pull it. But if I were to guess, most of the engine is still good. You can start it but it runs very rough and doesnt move the truck
Old Apr 28, 2018 | 12:38 PM
At this point what caused the rod brg to seize needs to be determined. As you are probably aware running it will only do more damage. Most dealerships don't want to get involved with rebuilding, installing a reman is less time consuming and more profitable.
You probably could use the engine, but there will be some differences due to emission stuff.
mbwilson
Nov 12, 2017 09:15 PM
_CURLEE_FRY_
Jul 16, 2017 10:30 AM
astrapous
Dec 22, 2008 10:13 PM
WildChild
May 22, 2005 11:53 AM
WildChild
Feb 3, 2005 01:08 PM
