shaking cab only when braking at 45 moh 2003 f150 4wd ???
Old Jun 3, 2023 | 08:53 PM
hightly's Avatar
Default shaking cab only when braking at 45 moh 2003 f150 4wd ???
I am having a vibration problem with my truck when braking or decelerating from speeds over 25 it shakes the truck horribly I brought it into Ntb and untop of several things the most likely cause was my passenger upper control arm I have changed that on top of several other things I will list at the bottom any help on this issue would be greatly appreciated thanks again
2001 Ford F-150 Larit 5.4 v8 4x4 vin:L
Parts changed:
Passenger upper control arm
Passenger inner and outter tie rods
Brakes and rotors
Both front hub assembly’s
Driver cv axel
Brake booster and master cylinder
All shocks
All new tires
Idler arm
this was a post back 2017. my 2003 f150 xlt supercab 4 wd is acting the same. shakes cab when brake hard down from 45-50 mph.
PLEASE HELP ME. ANYONE KNOW?!!
Old Jun 4, 2023 | 07:16 AM
There are some things that cannot be diagnosed over the net.. A problem like this requires a thorough inspection of all the brake parts, steering and suspension parts and this cannot be done without a physical inspection.
Are you sure the problem is originating from the front of the vehicle and not the rear?
Old Jun 4, 2023 | 09:24 AM
hightly's Avatar
no. a video of braking of under front end doesnt show much. im going to get it looked at monday. just thought its a problem that is common that im missing. good advice. thank u
Old Jun 4, 2023 | 11:38 AM
hightly's Avatar
Default video of shaking
video of braking from cab
Old Aug 22, 2023 | 08:18 AM
JW1979's Avatar
Definitely something worth getting looked at!
Nwong92
Dec 22, 2019 04:05 PM
